April 25, 2026, 03:52:04 AM
PlanePlotter version 6.4.4.3 now available for download - Released Mar 27, 2016
Started by Anmer, March 27, 2016, 06:19:08 PM
From Bev at COAA:
PlanePlotter version 6.4.4.3 is now available for download by following the link on the PlanePlotter web site:
http://www.planeplotter.com/#download
---Usual boilerplate---
You may need to exercise your browser Refresh function to force it to show you the new version of the PlanePlotter web page. If you post a message complaining that the web site is still pointing to an earlier version, you pay a forfeit !
If you have a version-specific firewall (eg Zone Alarm), you may have to reassure it that the new version is permitted to access the Internet. Be aware that some security systems treat any new file as a threat without any justification except that it is new. Please don't write to me about it; write to your security system provider.
If you have an installation of PlanePlotter running under Wine, this installer may not run. In that case (only), please download :
http://www.coaa.co.uk/planeplotter6_4_4_3.zip
which will be available shortly and unzip the files into the existing PlanePlotter application directory. Note that this will only work if PlanePlotter is already installed as it only contains the new file and not all the other files that are required to run the program.
New in version 6.4.4.3
Choice of Ground Stations for multilateration
This version uses an improved algorithm to choose the Ground Stations that are invited to provide raw data for manual mlats, auto mlats and scripted mlats.
Jaero support
This version accepts input from Jonti's groundbreaking Jaero application. ACARS messages received from the Inmarsat system via Jaero are plotted in pink with message type code 17.
Beast support
The input interface from the Mode-S Beast receiver has been updated to support the high message rates that the latest version of the Beast can provide.
OLE/COM output
A new parameter has been added to the OLE/COM interface to report the range of an aircraft directly, without requiring the script to calculate it if required.
180° meridian
PlanePlotter has always been rather lazy when it comes to plots that cross the 180° meridian. The outline feature now allows viewing an outline display that brackets the 180° longitude with coastlines and aircraft plots showing on both sides of the meridian.
NAT tracks
This version includes a workaround for the recent format anomaly in the NAT track GPX file.
Enjoy
Bev
COAA
