April 25, 2026, 04:48:32 AM
PlanePlotter version 6.4.4.7 available for download - Released 16th July 2016
Started by Anmer, July 16, 2016, 03:45:20 PM
From Bev at COAA:
PlanePlotter version 6.4.4.7 is now available for download by following the link on the PlanePlotter web site. "http://www.planeplotter.com/#download"
---Usual boilerplate---
If you have an installation of PlanePlotter running under Linux/Wine, this installer may not run. In that case (only), please download : http://www.coaa.co.uk/planeplotter6_4_4_7.zip and unzip the files into the existing PlanePlotter application directory. Note that this will only work if PlanePlotter is already installed under Wine as it only contains the new executable and not all the other files that are required to run the program.
New in version 6.4.4.7
QNH correction
The new version includes an updated list of METAR reporting stations for use with the QNH option. The old list included some obsolete stations.
This version also includes the ability to update the QNH periodically. Options..QNH setup (at the bottom of the pull-down) allows you to select automatic QNH refresh when changing the chart view or at regular intervals.
QNH is the pressure setting that shows the correct Altitude of the aircraft above sea level. If you specify a transition level in Options..Chart..Options, the PlanePlotter altitude/FL display will use the QNH below that level instead of the Flight Level which uses the QNE of 1013.2hP. Aircraft on the ground will then show the correct Altitude of the runway rather than the Flight Level, which might be quite different if the local sea-level pressure is different from 1013.2hP.
Data sorting
The 'a' window now sorts correctly, when required.
Circles method
The Circles method now retrieves the sharerlocations.txt file from the specified Chart directory where Options..Script..Download sharer location, places the file. This avoids the need to copy the file to the application directory. This change is to simplify operation if you have installed the program in the C:\Program files\ path, to which PlanePlotter cannot write.
*** The assumption is that the designated Chart directory is outside of that path. Note that if you use the Circles method, you will need to move your current sharerlocations.txt file from the application directory to the chart directory in order for this new version to work correctly.
PC clock correction
This release will enable me to apply a correction to the PC clock for those handful of users who are either reluctant or unable to meet the clock accuracy requirements for successful sharing. I had hoped that the use of NTP would become universal so that PC clocks were always accurate. It seems that was a forlorn hope in a few cases, so this version will deal with the problem in a different way.
Evaluation time extension
If you have exhausted the 21-day time limit for the free evaluation of PlanePlotter, this release will give you the chance to have another 21 days of evaluation time.
Enjoy!
Bev
COAA
