November 23, 2026, 12:11:30 PM
FD Error
Started by charliebrown, June 10, 2012, 10:14:18 AM
charliebrown
I have started getting a problem with FlightDisplay_7_9_64_0
It has stated giving the error message attached below.
Running SBS1-er, PP, FD and Active Display Lite on Windows 7 64 bit version.
Any suggestions how to put this right.
regards
Charlie
Hi Charlie
Do you get the message if you just run FD and not with AD at the same time?  And does the message occur randomly or always when you do something?
charliebrown
#2
Hi Mike
Only started happening this morning.
I start up Basestation then FD and this message then pops up even before I press the FD start button every time without Active Display or PP running.
If I then press the start button in FD, I get a series of these error messages every time and Windows 7 says the FD programme has stopped working wants to send the error to MS.
I would normally Start BaseStation, FD, PP then Active Display Lite in that order.
Charlie
Open Task Manager and see if any FD process are running in the Processes tab.
If they are, End them.  Then restart FD.  If you still get the error I'll ask Allan Bird for his advice.
charliebrown
Hi Mike
Tried what you suggested and still getting the errors.
Just noticed, I get message attached very briefly after pressing the FD start button before all the duplicated errors appear.
Charlie
Thanks Charlie, I'll get in touch with Allan Bird and get back ASAP.
charliebrown
Hi Mike
I thought I might try a reinstall of FD and this seems to have cured the problem.
Not sure what caused it in the first place.
Charlie
